Doing studs
Hey guys,
Well it's time to stud! I know many of you use o.e.m. Gaskets and arp studs so that's what I'll use but what else should I get before tearing in to this project. Also what should I have the machine shop do to the heads? I already replaced the oil cooler and deleted the egr. So I would appreciate a list so I'm not stuck waiting for parts. Thanks guys. Sent from my Autoguide iPad app |
Byrd,
I am doing the studs and gaskets very soon myself. I have everything and here's a list of what I will be doing, ARP studs OEM gaskets, Blue spring mod, stand pipes and dummy plugs, injector o rings and cu washers, IPR screen, stc fitting, CCV re-route, checking the heads for cracks before they are sent to the machine shop for inspection and machining using a Magnaflux Spotcheck Kit. This way I will not blind sided with surprises. Hope this helps. |
Yes it does help thanks!
