'06 with a new noise at start up - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-30-2012, 11:24 AM Thread Starter
My '06 just recently started making a screeching sound at start up. The noise comes about 2-3 seconds after start up and lasts only a second or two. My fuel mileage also dropped down to about 10.5 mpg reguardless of whether i'm on back roads or highways. Truck has an S&B intake, 4 inch mbrp, and and SCT tuner with the preloaded performance program. had a new FICM about a year ago and 2 new injectors put in at the same time. Any help would be appreciated.
watercutter.10 is offline
post #2 of 7 Old 01-30-2012, 11:33 AM
Term3's Avatar
Check idler pulley, I'm guessing a bearing is going.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 7 Old 01-30-2012, 01:37 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 242 Post(s)
how many miles on the belt and tensioner. may need one or the other or both
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is online now
post #4 of 7 Old 01-30-2012, 04:55 PM Thread Starter
The truck has had about 30k miles since i've owned it so they are at least that old. I dont know for sure though. It doesnt really sound like a belt though, its more of a metal on metal sound.
post #5 of 7 Old 02-01-2012, 04:58 PM
Quoted: 242 Post(s)
does your AC work ok? if you dont think its the belt or he tensioner, could be the clutch on the AC compressor.
post #6 of 7 Old 02-02-2012, 05:40 AM Thread Starter
As far as I know i havent had any problems with the AC... I havent had to use it for a while up here in ohio though. I'll have to check that out, thanks.
post #7 of 7 Old 02-02-2012, 12:06 PM
Quoted: 242 Post(s)
Doesnt matter wether you're using it or not, the compressor does cycle on when you you the defrost as well. Only thing I can suggest is unplug the clutch or pull the relay for it and see if the noise persists
