.2 volts on ICP and 0 psi?? - Ford Powerstroke Diesel Forum
Old 01-10-2012, 01:51 PM
I have the no hot start problem, ordered the STC fitting update kit but haven't put it in yet. Just want to make sure that's the actual problem before I tear into it. It runs fine but takes 6-10 seconds to start cold. After it's warmed up, I have 0 psi and .2 volts on ICP. I'm reading that from my edge insight. If it was the STC fitting, would I be getting 0 psi or should there be at least some pressure? Thanks in advance to any help.
Old 01-10-2012, 10:29 PM
anyone have a clue?
Old 01-11-2012, 02:18 AM
I think your ect is screwing up. If you actually had 0 psi your truck would not run.
This does not mean that you do not have some type of oil pressure loss. Actual testing with mechanical gauges is needed for verification.
Old 01-11-2012, 04:12 AM
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Something isn't right....are those readings while it's running? ICP should be .24ish KOEO.
Old 01-11-2012, 04:58 PM
while running, my icp voltage doesn't drop below .8 and pressure never goes below 600 psi. but after getting it to running temp i turn my truck off. then put it on acc so the edge comes on, i have 0 psi and .2 volts on icp
Old 01-11-2012, 05:56 PM
Those are correct readings.
Old 01-11-2012, 07:49 PM
Ok, so back to my original question. Should I be reading 0psi with the key in ON position like i'm getting ready to start it? I understand that a high pressue oil system leak will cause decreased pressure but should it have some pressure or none?
Old 01-11-2012, 08:39 PM
with the engine off, there is no high pressure oil. The reading is normal. When cranking you need around 500 minimum.
MikeB
Old 01-12-2012, 04:11 AM
Mine is always 0PSI at start up.
Old 01-12-2012, 09:44 AM
will check tonight when i get home and post numbers back up. thx
