white smoke oh no
Last night i turned the sct tuner all the way off because it was a pain to start and couldn't drive for a while until it hit high idle. Today it was worse loped for close to a min then waited about 5 min to warm up some. Then took off to the store ran normal, turned a corner and white smoke just poured out. No coolant is missing when it did it, it ran like **** missing no power what so ever then clear up and back to normal. came back out of the store started just fine coolant at operating temp and did it again seemed at less than 1/4 throttle it was okay anything more and had less power missed and white smoke went to ford he told me probably a few injectors out or coolant coming out. Any way it could be a icp sensor? never checked ficm voltage but it has started like this sense september. have rev-x here but not in the oil. its 60 degrees here today, and also replaced all 8 glowplugs with the harness before christmas.
oem fuel filters with 7k
oem oil filters with 2k on rotella t3
always has additive in the tank
