thinking i need a new turbo - Ford Powerstroke Diesel Forum
Old 01-08-2012, 07:28 AM
lately i've noticed that it take a long time to spool and build boost, if i hold the pedal to the floor, it will rev to about 2200 rpm and take a bout five seconds to start building boost, then will build about 29, usually doesn't go above 24. cruising down the road, at about 55-60 i would normally have about 10 pounds now has nothing, and has about an 800 egt, no load. everyone i've talked to said the turbo is shot, but wanted more input into it, before i order a turbo.
Old 01-08-2012, 10:03 AM
could be sticking veins or bad unison ring. there is a way to test the movement with a magnet. if its bad, you may wanna look into a powermax turbo because u have arps.
Old 01-08-2012, 10:07 AM
i was thinking the same thing about the powermax. and ive been reading that an edge insight should read the movement of the veins but mine dont show that pid at all.
Old 01-08-2012, 11:12 AM
Take your turbo out and clean it. Sounds like your VGT veins are stuck open. Just do a search on "turbo cleaning" on here. Also when you have it out make sure that you can push the plunger on the end of the VGT solenoid. It should move back and firth easily and smoothly with your finger. If you can't move it or if it is not smooth replace the VGT solenoid. It should cost about $30 to clean it, a lot better than $2k for a new one.
Old 01-08-2012, 11:27 AM
information regurgitator
No boost to little boost
Check that thread for more info about low boost, removing/installing the turbo, cleaning the turbo and some suggested parts to consider updating at the same time.
Old 01-08-2012, 11:35 AM
i read that other thread, and you say that the ebp sensor can cause this, and that code appeared on my insight, so that could be my problem?
Old 01-08-2012, 11:36 AM
Yep. The PCM uses the EBP sensor, MAP, MAF and a few other sensors to determine proper boost. Clean the sensor and make sure the tube isn't clogged with soot.
Old 01-08-2012, 11:41 AM
should mine be in the same spot as that 05, and all i do is run a wire down the tube, if its clogged do i need a new tube?
Old 01-08-2012, 11:44 AM
It will be in the same spot. It is a sensor sitting on top of a stainless steel tube about as big around as a brake line (ok, a little bigger than that, but you get the idea). Shoving the tiewire down in the tube will clear a clog, if there is one. Just poke it down in there and wiggle it all around. Easy beans.
Old 01-08-2012, 11:45 AM
sounds good, ill try that. thanks for your help
Tags
ford 6.0
