04 bad miss any sugesstions - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-08-2012, 08:09 AM Thread Starter
my step dad has an 04 6.0 recently started missing really bad no power hardly at all no CEL on ever any ideas?
Dave
2006 f250 FX4 CC SB
SCT X3
5" straight pipe 8" tip
completely new turbo internals
ARP Head studs, black onyx gaskets
updated oil cooler
EGR delete
Oil stand pipe o-rings
6" lift 37x14.50x20 Nitto Terra Grappler with monster XD rims
Diesel-dick-3283 is offline
post #2 of 6 Old 01-08-2012, 11:04 AM
injector sticiton maybe. have him switch to 5w-40 synthetic. maybe use rev-x too. test the ficm voltage tho.
joe_r_dog is offline
post #3 of 6 Old 01-08-2012, 12:31 PM Thread Starter
Tested ficm it's good 47.8V
Dave
2006 f250 FX4 CC SB
SCT X3
updated oil cooler
EGR delete
post #4 of 6 Old 01-08-2012, 01:22 PM
fixxxer-upper's Avatar
Do you have any way to monitor the engine? A "miss" could be a ton of things and we will all be guessing at this point. I too had proper FICM voltages. After extensive testing and replacing parts, my issue still ended up being the FICM on the logical half of the unit.
2004 (9/16/03 build) 6.0 FX4 Lariat CC
6.5" Pro Comp Lift with Dual MX6 Shocks up Front, 37" BFG KM2's, Power Slot Cryo Rotors & Hawk Pads, Moog Ball Joints, 4" MBRP SS Turbo Back CAT Delete, Coolant Filter, RCD EGR Delete, Zoodad, Harpoon, blue fuel pressure spring, ScanGaugeII, updated turbo drain pipe
fixxxer-upper is offline
post #5 of 6 Old 01-08-2012, 03:24 PM Thread Starter
he has no way to monitor it. what was your truck doing? my FICM went bad recently but my voltage was like 32.4 his truck literally sucks right now, it doesnt smoke at all white or black never has.
Dave
2006 f250 FX4 CC SB
SCT X3
updated oil cooler
EGR delete
post #6 of 6 Old 01-08-2012, 07:09 PM
I was getting circuit high codes on cylinders 2 3 5 8. The truck sounded like it was missing. FICM voltage held at 48.0v. Swapped in a loaner FICM and everything returned to normal. So I replaced my unit.
