LONG START - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-07-2012, 11:03 PM Thread Starter
JD_MILLS's Avatar
LONG START
Well im sure y'all are getting tired of seeing my name and questions on here but i've got another. had the ficm repaired about a week ago kept getting a p2552 code finaly got it to go away. and now its taking longer to start but no pattern to it. temperature doesn't realy effect it. it starts fine sometimes when hot or cold. then others drags out and takes between 10-15 seconds. any ideas? thanks for the help gentlemen
2008 f-250 LARIAT, SCT LIVEWIRE, S&B CAI, 8" MBRP STACK
JD_MILLS is offline
post #2 of 10 Old 01-08-2012, 10:19 AM
are u using OEM filters and OEM cap. may be dummy plugs or stand pipes. do u have a way to monitor icp. could also be injector oring. also, how are batteries, they must be 100%
joe_r_dog is offline
post #3 of 10 Old 01-08-2012, 10:52 AM Thread Starter
JD_MILLS's Avatar
All filters are motorcraft.
Sent from my SCH-I500 using AutoGuide.Com
JD_MILLS is offline
post #4 of 10 Old 01-08-2012, 12:02 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Ok, the filter is Motorcraft, but are you sure the cap is Motorcraft? Many aftermarket companies make their own cap, and if you were to use it, would create the condition you are having.
Please
You could save the life of a sick child
NYC F-350 is offline
post #5 of 10 Old 01-08-2012, 01:31 PM Thread Starter
JD_MILLS's Avatar
Its all motorcraft. Filters and caps
Sent from my SCH-I500 using AutoGuide.Com Free
JD_MILLS is offline
post #6 of 10 Old 01-08-2012, 02:41 PM
im puttin my money on batteries then. if they arent fully charged, they can make it act weird, like long crank time. used to happen to me. i got 7yrs out of my originals.
post #7 of 10 Old 01-08-2012, 03:08 PM Thread Starter
JD_MILLS's Avatar
I've been thinking that myself. I've had the truck about 7 months and whoever had it before me replaced one battery but not the other. So I think the over one is going bad. Probably go ahead and put two new ones on it.
JD_MILLS is offline
post #8 of 10 Old 01-08-2012, 03:37 PM
when i replaced mine, i saw a huge difference in cranking speed. i was almost scared at how fast it turned over. thats good tho, also have the alternator load tested by an auto parts store, its free.
and that is a good lookin truck
post #9 of 10 Old 01-08-2012, 04:02 PM Thread Starter
JD_MILLS's Avatar
I know the alternator is hopefully its just gonna be battery.
JD_MILLS is offline
post #10 of 10 Old 01-08-2012, 09:51 PM
ford fanatic's Avatar
Thread hijack, dumb question maybe, but will it say Motorcraft on it? I'm doing my first oil change soon, and want to use the right cap. Thanks.
06 F150 Scab 4X4
05 Ranger 4 banger beater
13 Explorer Sport (wife's)
Powerstrokes Sold...
E99 Reg Cab 6 Speed
02 Scab 4X4 Lariat
06 CCSB 4X4 Lariat
ford fanatic is offline
