6.0 very low boost after i did egr delete and exhaust - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-07-2012, 06:28 PM Thread Starter
HI,
I just installed an egr delete kit and exhaust on my 05 6.0. after putting it all back together i had a hell of a time getting it to start, i did not un hook and fuel related items. it would crank but no smoke at all. it has done this 3 times in the past but always started after several cranking cycles. this time i gave her a very very small snort of ether and it started and has started several times since than no problem, both when it has been cold or warm. my other issue is i cannot get any higher boost than about 8lb. i took the turbo back off and ripped it apart and cleaned everything and it seems to all move freely. it is back together and still the same issue, might even be a little worse. what should i look for next? i hate to take it to the garage, i have always done all my own work and all the new electronics are driving me nuts!! any help would be greatly appreciated.
Thanks,
Chuck
kradel acres farm is offline
post #2 of 7 Old 01-07-2012, 06:36 PM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
exhuast leak somewhere... look for black soot traces on your firewall and you know where it is.
Make sure that when you connect the turbo the flanges are tight together. The clamps WILL NOT bring the flanges together when tightening!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #3 of 7 Old 01-07-2012, 06:41 PM Thread Starter
i also checked for exhaust leaks and there are non visable anywere, also no smell of exhaust.
post #4 of 7 Old 01-07-2012, 06:52 PM
2003kingranch's Avatar
This might sound crazy but is your vgt solenoid plugged in?
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #5 of 7 Old 01-07-2012, 07:02 PM Thread Starter
yep the vgt is plugged in, i tried un-plugging and plugging it several times just to make sure. is there a way to check if the accuator is moving the veins?
post #6 of 7 Old 01-08-2012, 05:46 AM
Do you have any king of gauges or scanner? If you do you can look at the vgt duty cycle to see if its working
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
post #7 of 7 Old 01-08-2012, 03:55 PM Thread Starter
Thanks for your help guys, i found the problem this morning, it was the 1/4 inch line from the intake to the sensor that operates the vgt. i must have bumped it while doing the other work, it had a very tiny crack in it, she is good to go now and the mileage went up almost 3 mpg in town!! Thanks again
