Oil change problem
Changed oil to t6 5-40 today. Now it has a miss that will not go away. Its in the shop where it is 60 deg. it used to miss a little on start up but would come oit of it. I used to use 10-30. Anyone have any ideas?
Sent from my DROID BIONIC using AutoGuide.Com Free |
Put scanner on it and got a p0264 cylinder 2 injector circuit low. Any one know what this might be?
Check the voltage on your FICM. It should be roughly 48 volts. That code isn't cause by your oil change.
I also did the blue spring upgrade today but with it running bad I put the stock spring back in didn't help runs the same
48v all the time
I got it, some how the connecter on #2 injector was a little loose. Got it back on correctly and runs like a top
