03 6.0 eot/ ect - Ford Powerstroke Diesel Forum
post #1 of 23 Old 01-07-2012, 08:20 AM Thread Starter
lsutigerfanforlife's Avatar
03 6.0 eot/ ect
I was on my way to work this morning and my ect was at 190* and eot was within 10-12*, thing is I cranked the truck before I left and it ran for about 15 minutes then drove 6 miles to work, don't know if those are high temps for that short of drive
lsutigerfanforlife is offline
post #2 of 23 Old 01-07-2012, 09:32 AM
If you have the stock cooler then you ECT and EOT should climb up at pretty much the same rate. I will assume that you was not pulling anything and that is was all mostly country driving just cruising, so that delta seems a little high to me. It is within limits but I would closely monitor your delta's. Your cooler might be slightly clogged. What kind/color of coolant are you running? Do you have a coolant filter?
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #3 of 23 Old 01-07-2012, 10:09 AM
You may also consider a different motor oil for winter and take a look at how dirty your radiator,air charge cooler etc. Restricted air flow can cause some problems as well.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 23 Old 01-07-2012, 10:41 AM Thread Starter
Ford gold crap no coolant filter, I've been meaning to flush that crap out but haven't had time, and dannyboy where is the air charge cooler?
post #5 of 23 Old 01-07-2012, 11:00 AM
In front of the radiator.
Has air inlets on each side. Comes out pretty easy.
I took my air cooler and my radiator to the local radiator shop and had them douche them out on their big tank. Flushed out all kinds of gunk. Cleaned the fins out like new as well. Think it was 20 bucks or so.
tony 340 is offline
post #6 of 23 Old 01-07-2012, 11:15 AM
Lilfarmrboy's Avatar
I have an 05 and it only takes me about 8 minutes to get to work. My ECT runs at 190 and my EOT runs 185 to 195. Usually its withing 3 to 5 degrees unless I am working her hard. When I am working my truck hard the most it goes is 10 to 12 but usually comes back to within 3 to 5 after getting up to speed on the highway.
Lilfarmrboy is offline
post #7 of 23 Old 01-07-2012, 11:39 AM Thread Starter
Well I'll take a look into that, also my boost only tops out at 22 and that's running an 80hp tune, is that normal
post #8 of 23 Old 01-07-2012, 12:24 PM
Thats about right for the boost if you are running without a load on.
post #9 of 23 Old 01-07-2012, 03:31 PM Thread Starter
monitored my ect/ eot on the way home from work today, fired the truck up pulled out of the parking lot, not high temps but my ect got up to 16* over eot, problem?
post #10 of 23 Old 01-07-2012, 05:11 PM
How long was your ride? I can't remember what TSB it was but in general never look at the numbers for the first 20 minutes. The truck has to be warmed and up to normal op temps before you can see if you really have an issue. Ford test the truck in empty and under load conditions to determine if you have a failed oil cooler. Not really a good idea to use the numbers from the first 20 min if the truck was cold, ie sat over night.
