2005 6.0L crank/no start - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-06-2012, 02:46 PM Thread Starter
Trying to figure this out, I'll start with the simple things. Yes it has fuel, new fuel filters the fuel is getting to the final filter housing. Not getting any smoke out of the exhaust while cranking. Gave it a small hit of either and still nothing. Replaced the ICP as its a fast fix with the new pig tail. Removed the IPR screen looked good but the internal housing was moving around so I replaced that as well. I'm not getting any codes for the FICM let alone anything at all. Not quite sure but I'm thinking HPOP but have never tested one before.
JJameson is offline
post #2 of 9 Old 01-06-2012, 04:16 PM
boostrooster's Avatar
Did you test the voltage for the FICM; it wont throw a code if its not producing the voltage
boostrooster is offline
post #3 of 9 Old 01-06-2012, 04:19 PM Thread Starter
The trucks voltage is going down to 11.5 during crank and the voltage in the FICM is fluctuating between 47-48 volts.
JJameson is offline
post #4 of 9 Old 01-06-2012, 04:49 PM
What do you have for HPOP Psi during crank. It needs 500 psi to start Check your injector harness and Ficm harness connectors Did you recently complete some repairs or as it got cold we need some more info
2005 F350 CCSB Lariat
6.0
Cooper AT3 270/70/18
ARP and oems
Bulletproof EGR cooler (deleted)
Bulletproof Oil Cooler
SCT SF3 w/vivs tunes
08 tailgate and lights
6K HID in Headlights and Fogs
Reese Gooseneck and Laverne Bumper
60 gal Aux/tool
Pioneer DVD-4300
bulldog55964 is offline
post #5 of 9 Old 01-06-2012, 04:58 PM Thread Starter
injection control pressure is below 100 the FICM connectors are good pulled them and inspected the pins. missed checking the injector harness (oops on my part) FICM was "replaced" not new but from a working truck I did not replace it so I cant be sure. The ICP being below 100 is my guess on the HPOP (forgot to put in orig post sry) but wet for the ICP w/ pigtail because it was pretty easy and I know the stock pigtail was having issues. I'm just not sure on the HPOP, if there is something easy to fix on it or if I need to pull it. also the desired pressure is 1530 psi. Not very savy with the 6.0 so not sure if thats a normal desired psi or if there is another issue that im missing completly.
JJameson is offline
post #6 of 9 Old 01-06-2012, 05:03 PM
Oem filters and caps? I would guess STc fitting. Hpop's going out on 05-07s is uncommon. Do an air test to try and locate the leak.
joe_r_dog is offline
post #7 of 9 Old 01-06-2012, 05:10 PM Thread Starter
wix filters for the fuel new as of yesterday. I'll give the air test a try tomorrow and give you guys an update.
JJameson is offline
post #8 of 9 Old 01-06-2012, 05:14 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 274 Post(s)
STC fitting,standpipes, and dummy plugs I think are the common problems with 05 HPO system. Kinda funny it hasnt thrown a low injection pressure while cranking code though.
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #9 of 9 Old 01-06-2012, 06:08 PM
^^^ Ditto Whats your LPO psi cause if you dont have oil going to HPO it wont create psi
6.0
ARP and oems
60 gal Aux/tool
Pioneer DVD-4300
