2003 6.0l excursion died not wont start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-06-2012, 11:12 AM Thread Starter
If anyone can help.. please....
Wife was driving to work, truck shutdown on hwy and now will not restart.
No codes are stored, cranks but will not start.
Any thoughts on where to look?
Oil and fuel filters changed 1 week ago, as well as fuel pressure regulator. due to leak.
has 142.000 miles on truck.
Thanks
skeeter7310 is offline
post #2 of 4 Old 01-06-2012, 03:54 PM Thread Starter
So I was able to get 3 codes out of the truck
P0603
p2290
p0300
Any ideas?
post #3 of 4 Old 01-06-2012, 05:07 PM
Oem filters? It's probably a hp oil leak. Must be 500psi to fire injectors. It could just be the icp or ipr. U will need something like the scangauge2. Ur hpop could've went bad too. But u need to get a hp oil reading.
joe_r_dog is offline
post #4 of 4 Old 01-06-2012, 05:18 PM
P0603 is dealing with PCM and if it's chipped. It's not bad.
P2290 is icp pressure too low. Check the icp sensor which on an 03 should be around the turbo area. If it has oil on it and the pigtail, replace both.
P0300 is a random cylinder misfire code. They r very uncommon and usually go away after cleared.
