Block Heater tripping GFCI - Ford Powerstroke Diesel Forum
Old 01-04-2012, 12:25 PM
Question Block Heater tripping GFCI
After I plug the block heater in after about 5min or so, the GFCI trips. Tried another outlet/circut and different cord, but same thing happens...Short in block heater? Anyone else had an issue with this?
Old 01-04-2012, 12:44 PM
lug lug is offline
I had same problem with a block heater in a 99 Blazer up in Alaska. The element got coolant inside and popped the GFCI. Replaced the heater and problem was solved. I did check my power cord first for obvious signs and then a continuity check.
Old 01-04-2012, 12:52 PM
duct tape & zip ties
It could be the plug on the cord, it could be the element. I really don't know of anyway to check them.
Last time I bought the block heater was like 45 dollars, the cord is another 20-30 bucks from the dealer.
Old 01-29-2013, 10:12 AM
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
I noticed my truck not heating up with the block heater this morning. My extension cord has a lighted end so I know when it has power...the GFI was tripped, and would not deliver power to the cord unless I unplugged the cord from the truck. It has been cold and raining the past two days, so I may not get a chance to look at it for a few days. How had is it to get the element or cord out for replacement?
Old 01-29-2013, 11:20 AM
yup mine does this too
Tags
block heater, breaker, gfci
