head gaskets and or injectors - Ford Powerstroke Diesel Forum
Old 01-03-2012, 05:42 AM
Question head gaskets and or injectors
Calling all strokers bran new on here so ill make it short. 04 f350 pukin coolent dealer said gaskets are gone.Three injectors dead all misfireing. So now my question is witch should i do first injectors or hg's i plan on doing injectors myself but the gaskets different story......help me out boys
Old 01-03-2012, 05:57 AM
Slacker
Feedback Score: 4 reviews
Welcome to the ORG. Sorry to hear about your truck. How did they determine that your head gaskets have blown and that you have 3 bad injectors? How many miles on your truck? Also, is your truck an early or late 04?
Old 01-03-2012, 06:03 AM
late 04 on the scanner as far as i know just hit 200000 mile marker.
Old 01-03-2012, 06:13 AM
First thing you need to do is remove E G R vavle and see if it is clogged with black paste in and on and around vavle.... If it does seem wet, then you have a blown E G R..... Change your E G R cooler and your OIL cooler because your OIL cooler went bad and took out your E G R cooler...... I have a shop in Dallas Tx.
Old 01-03-2012, 06:21 AM
The injectors are better to do asap because you will get better fuel milage. not to hard to do. I would change the dummy plugs on both sides and stand pipes as well.
Old 01-03-2012, 08:57 AM
whats a dummy plug and stand pipe???please note im very new?
Old 01-03-2012, 10:16 AM
Carbon huffing animal
IF, you have blown HG's, and IF it is causing fluids to mix, and coolant in the oil, it is critical to stop driving and fix the HG's ASAP.
But, IF an injector is bad to where it's dumping fuel into the cylinder, that is also critical to park it, and replace injectors ASAP.
from what I've learned, 200k is a pretty fair life for 6.0 injectors. It would be advisable to replace all while you're in there.
