6.0 L runs rough - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-02-2012, 10:35 PM Thread Starter
6.0 L runs rough
One day my 6.0 L diesel was running smooth. The next day I noticed it running very rough when I accelerate from cruising speed of approximately 1900 to 2000 rpm. E.g. not running on all cylinders. When running at lower rpms and accelerate it does not seem to be as noticeable a problem. When I back off demand it seems to temporarily stop. My guess is either clogged injectors or fuel filter. I have used an injector cleaner and anti gel additive to a full tank of fuel and have gone through at least a third of a tank, but it does not seem to be getting any better. This problem I am experiencing came on suddenly. It makes me wonder if I picked up bad fuel. I suppose I am in for a diagnostic check. Is there anything else that I should be looking at?
bobwstanton is offline
post #2 of 8 Old 01-03-2012, 06:43 AM
just wondering how does is do on first start up
BaLaMo3 is offline
post #3 of 8 Old 01-03-2012, 12:06 PM
could be injector stiction. just a guess. what oil do u run and how often on changes?
joe_r_dog is offline
post #4 of 8 Old 01-03-2012, 04:10 PM Thread Starter
6.0 L runs rough
Thanks for the reply. It starts easy initially, but it is idling somewhat rough as well, despite that I have injector cleaner and anti-gel fuel additive. None of the idiot lights come on. I was thinking of replacing the air filter as the easy first step.
Bob
post #5 of 8 Old 01-03-2012, 07:14 PM
I switched to rotella T6 recently and am now having a cold start issue. The engine runs rough and suspect stiction.
Any ideas my friends?
csamus is offline
post #6 of 8 Old 01-03-2012, 07:51 PM
JD_MILLS's Avatar
the t6 synthetic should aid in cold starts.
2008 f-250 LARIAT, SCT LIVEWIRE, S&B CAI, 8" MBRP STACK
JD_MILLS is offline
post #7 of 8 Old 01-04-2012, 07:34 AM
southend's Avatar
Sounds like what mine did, mechanic put out on the diagnostics machine, #4 injector is bad. He told me to replace with ford injector. 04 powerstroke with 168k.
southend is offline
post #8 of 8 Old 01-04-2012, 07:42 AM
southend's Avatar
By the way, I was running injector cleaner in mine when it started acting up. I've only had it a month, I guess I should have left it alone. I.m going to fix it though.
southend is offline
