Coolant leak - I think I located it, but I do not know what it is - Ford Powerstroke Diesel Forum
Old 01-02-2012, 09:59 AM
I found the leak that's giving me trouble. Coolant immediately leaks from this area if you put any in the degas bottle.
This area is right behind one of 2nd highest wheel for the belt, above the water pump. Here are some pictures I was able to get..
Coolant leak - I think I located it, but I do not know what it is-imag0175.jpg   Coolant leak - I think I located it, but I do not know what it is-imag0176.jpg   Coolant leak - I think I located it, but I do not know what it is-imag0177.jpg
Old 01-02-2012, 10:04 AM
information regurgitator
There is a "donut" (BIG o-ring) where the intake manifold meets the front cover right there.
Old 01-02-2012, 10:44 AM
This thread is just in the last few days. Go to the end and you will see the whole process.
Passenger Side Coolant Leak - From Where?!?! - Ford Truck Enthusiasts Forums
Old 01-02-2012, 01:03 PM
thanks guys, this really helped! not sure if i want to dive into this myself, looked like a lot of work and i dont want to cause more problems lol
Old 01-02-2012, 01:13 PM
It will be time consuming, but not terribly difficult to do.
Basically the turbo comes out and you need to loosen all the intake manifold bolts enough to lift the front of it to get the o-ring out and the new one back in.
Might be a good time to consider an egr delete install if you don't have one on there yet (and can install such a thing).
I have directions posted for turbo removal/install and intake manifold removal/install that can be found by clicking on the "step by step egr and oil cooler replacement" link in my signature line. In that thread, I also have some notes about getting the exhaust all lined back up post repair (which can be more difficult than anything else..if it so decides to be).
