P2552 CODE
Okay just replaced my ficm now i'm getting code p2552 i've checked all wires about three times now and haven't noticed any loss in power. the turbo psi gauge is acting strange now (reached about 27 psi never has before) any help will be greatly appreciated
P2552: FICMM (fuel injector control module monitor) Circuit-Throttle/Fuel Inhibit circuit
Here is what it is and what it does: Quote:
Could that cause the transmission to shift weird?
I'm sure that it could.
could the new ficm cause that? shoud i see if they'll give me a new one?
By reading the pinpoint tests, most of them point to this being a harness issue and not a FICM issue.
If you have a friend close by with a 6.0, you could try another FICM. I imagine it could be an internal FICM issue as well. |
Guess I should have asked the definition of "new FICM" here... When my FICM took a dirt nap on me about a month ago, I got one from a forum member that was on an 03 model. It works just fine in my 06 (actually it runs better now than when I had the 06 FICM). I doubt the 03 had the same ECM strategy, though anything is possible. |
I have the original one it was repaired. i had a p0611 code had it repaired and started getting p2552 code now. something isn't right about it.(can't quite put my finger on it) it doesn't seem to have lost any power though. transmission seems to be shifting strange also though. seems like it couldn't find the right gear. and my turbo psi gauge started moving with the rpm gauge and went up to about 30 at wot. it used to stay around 10 wheather its idling or the rpm's where around 3000 so i'm clueless
It sounds like you may have a the 6.0 electrical boogieman living under your hood. |
