po113 code won't clear
New to the forum great place for info. I had several problems now iam down to po113 code replaced the iat sinsor it was gummed up. can't clear code. My problem is cold running classic no power and smoke till warm up. ficm 48v. good fuel pre. everything checks out on scanner but po113.stuck don't know were to go next help!!!!!!!!!!
I had an IAT related code. Did all of the troubleshooting and it pointed to replacing the IAT. New IAT did not solve the problem...
I went back to re-do the troubleshooting procedure, and I finally noticed that there was a mostly broken wire right at the IAT plug. This connection gets a pretty hard kink - may want to look there. Otherwise you will need to ohm out the wires from IAT to PCM to see if there is another wiring issue. MikeB |
I will look at that. I have a S&B cold air intake on it with no maf sinsor but I haven't had any trouble with that I also ordered rev-x today going to try that with oil change I am running 10-30 rotella syn. I am in Ky. gets cold here going to go to 5-30. On my scanner the IAT was reading 5.2v . Will report after change next week thanks Mike.
What year is the truck?
