2003 6.0 died while driving - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-29-2011, 02:55 PM Thread Starter
2003 6.0 was driving down the road noticed it was low on power pulled up to stop light and it died and wouldn't start back the truck also has oil leak at back of motor i think at icp went to load on rollback and about half way loaded and tried to start and it started but now won't start at all any clues as to what it could be
bigjeff is offline
post #2 of 6 Old 12-29-2011, 03:09 PM Thread Starter
just went out and started truck it started i pulled in to garage reved up motor and noticed the idle picked up then truck died again and would not start back is it the icp sensor or what
bigjeff is offline
post #3 of 6 Old 12-29-2011, 05:21 PM
Yes, I would start with the ICP sensor and maybe a new pigtail to go with it. Do you have a way to pull codes or get ICP and IPR data? See the t-shooting guide in my sig for more info. The next time it does this pull the plug on the ICP sensor and see if it starts.
HAM_RADIO_MAN is offline
post #4 of 6 Old 12-29-2011, 06:02 PM Thread Starter
hooked up to code scanner did not have any codes
bigjeff is offline
post #5 of 6 Old 12-29-2011, 07:40 PM
Get a scangauge2 for monitoring icp readings. Does sound like icp tho.
joe_r_dog is offline
post #6 of 6 Old 12-29-2011, 08:15 PM
d and b installer's Avatar
unplug the icp if the contacts have oil on them then the icp is shot. they are expensive but can be changed out in about an hour including the pigtail. easiest way to do it is form under the truck. There is a heat shield between the block and y pipe. its removed with 2 10mm bolts and i believe an 8mm bolt. take a 1 1/16 wrench and cut the box end down to 6 inches long can be bought at oreilly auto parts for less than 20 bucks if i remember right. unplug the icp put the wrench on the sensor push up may have to tap the wrench with a long prybar and hammer. Half to 3/4 turn should loosen it enough to remove by hand. remove the old one then quickly install the new one the less oil lost the easier it is to restart the truck.The icp does not need to be installed very tight about a half turn more than hand tight works great. From above disconnect the IRP valve wiring and lift the harness holder off of the stud next to it, you can now pull the harness out far enough to do the needed surgery to it.
My truck
2003 f250 6.0 , 5r110
, afe stage2 intake, diamond eye 4 inch exhaust dumps in front of passenger tire, arp headstuds, Swamps 58V FICM
, SCT Tuner canned tunes for now, welded egr cooler, Bodywork by trailer in the ditch.
made new by Tech Auto Body
, Blue Ox goose neck hitch
. gone the bank said I couldn't keep her R.I.P.
d and b installer is offline
