Head Gaskets Just Done Whats Acceptable Coolant System PSI - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-28-2011, 07:09 PM Thread Starter
I just had the head gaskets replaced on my truck about 3 weeks ago. We replaced the head gaskets with OEM gaskets, did the head studs, all the other gaskets too, and cleaned the oil cooler. Truck has an EGR delete on it too. The thing the tech told me was that both heads were warped about .002, but were within Ford's acceptable specs. The heads weren't sent out and checked, they were just given a visual. I've put almost a 1000 miles on the truck since the head gasket repair. I'm currently running a Superchips 1855 Tuner, with the Milage XS tune. I got to say the truck runs great with this tune on it. I don't drive the truck like I stole it. I really love this truck. I have a PSI guage hooked in with the Degas bottle. How I found out that my head gaskets were blown was the PSI guage was hitting about 18 to 20 PSI before. Now the PSI guage runs between 11-13. I've seen the guage reach almost 14 PSI the other night, but I was really on the truck. There is no information here on the net that I could find to determine what the normal coolant system PSI is on a 6.0. Do you think my PSI is within the acceptable range of about 12 to 13 PSI? I purchased this truck in Aug of this year, and the truck has never once puked on me.
jayrw123 is offline
post #2 of 5 Old 12-28-2011, 09:20 PM
smuesse's Avatar
Subbed, Iv been wanting to know the same thing. How did you hook in the gauge?
Scott Muesse
Hubbard Texas (Near Waco)
1999 F-350 7.3 4x4 CCLB
2015 Palomino Puma 30-RKSS
'73 F-100 Restoration Project
'05 ClubCar gas golf cart
smuesse is offline
post #3 of 5 Old 12-28-2011, 09:26 PM
2003kingranch's Avatar
from what i have read the cap pukes at 16 psi.
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #4 of 5 Old 12-29-2011, 07:10 AM
Arctic Fox's Avatar
Quoted: 9 Post(s)
Feedback Score: 8 reviews
I have a PSI gauge hooked in with the Degas bottle. How I found out that my head gaskets were blown was the PSI gauge was hitting about 18 to 20 PSI before. Now the PSI gauge runs between 11-13. I've seen the gauge reach almost 14 PSI the other night, but I was really on the truck. Do you think my PSI is within the acceptable range of about 12 to 13 PSI?
It's unfortunate that you didn't insist on having the heads milled flat, because Ford's "acceptable specs" are not acceptable, but at least they used OEM gaskets.
Hopefully you won't have to do head gaskets a 2nd time... I found out the hard way (and expensive), after only 6000 miles the gaskets were leaking again, so the second time I had the heads milled and used OEM gaskets.
I think 10 to 12 psi is okay
2006 F-450 XLT 4x4 Auto 4.30L Alcoa 19.5" 16,000 GVWR
Kelderman 4-Link/4-Bag Rear Suspension, Lariat Seats, '08 Console, '11 Mirrors, CTS, SCT X3
ARP's w/OEM HG, BPD 6ph FICM @ 58v, BPD Oil Cooler w/stat, Ported Intake, 185 amp Alt
P-Max w/WPE billet wheel, Spearco IC, 4" Banks Exhaust, Shell T6, Zerex EC-1, Oil bypass filter
49,000 miles
Arctic Fox is offline
post #5 of 5 Old 12-29-2011, 08:46 AM
+1 to this. Wish you the best of luck.
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
