Cold start issue. Need help! Lost Bully Dog when flashed! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-25-2011, 05:58 PM Thread Starter
Had my batteries go bad. Long story short.. New batteries, new crank and cam sensor, new FICM, new cam sensor connector plug. Cleared codes and flashed, updated. Truck only starts when plugged into block heater, otherwise won't start. No block heater, no start. Glow plugs read good. Throws no codes when hooked up to scan tool, or Laptop. Any ideas? Also had truck reflashed, didn't think about or know this and seems that my BullyDog program is lost. Any ideas or thoughts on my options?
flippedoverford is offline
post #2 of 9 Old 12-25-2011, 06:09 PM
Powerstroke Techie
justinmix's Avatar
Little confused here. So it started fine before you replaced all that and now it won't? Or you did all that because it wouldn't start and now it still won't start? What year truck and how many miles? What is FICM voltage at when cranking? Does KOEO test pass fine? During injector buzz test do you hear 8 distinctive clicks or "buzzes"? After you get it started does it run good with no missing or low power? Does it even try and start if you don't have it plugged in?
If you didn't pull the bully dog programming out before you had it reflashed then yes, it's gone. You will have to get in touch with bully dog to get it working again.
justinmix is offline
post #3 of 9 Old 12-26-2011, 03:26 AM Thread Starter
2004 with 75,000 miles.Truck will not attempt to start untill plugged in. I did not test anything myself, but was there when the tech had it on his laptop. It gave no codes. It wouldn't start untill the new cam sensor was installed. The new cam sensor was installed and it ran good but would only start when plugged in. At this point I took it to a well respected Diesel shop here in Wisconsin. He called and said the FICM was bad, and it had codes and needed an update. He did the FICM, cleared the codes and installed the update. Took it home, let it sit overnight. No start in A.M. Took it back, he installed a pigtail on the Cam sensor. He said those commenly go bad on the 04's. Took it home again, let it sit overnight, no start in A.M. Plugged it in. Starts right up. Runs, good, starts good when plugged in. Looking for some possibilities as I will be calling the garage tomorrow. As far as the Bullydog, kinda figured on having to call them.
post #4 of 9 Old 12-26-2011, 04:56 AM
Powerstroke Techie
justinmix's Avatar
Hmm, hard to say what's going on without knowing what the truck is doing. Best thing to do would be to ask him to watch ICP pressure during cranking. As long as that's getting over 500 psi then it's fine. I'd also watch FICM voltage while cranking, but it should be good if they just did the FICM. I would also watch for FICM sync during cranking. The FICM needs to see both cam and crank sensor readings before it will try and fire the injectors. I know they did the cam sensor but they might need to do a crank sensor as well. Most times people will replace them in pairs.
post #5 of 9 Old 12-26-2011, 05:45 AM Thread Starter
Crank sensor was done as well. Problem is by the time I got the truck to him it was already warm so it started no problem, and the cam and crank sinked on his laptop as well...
post #6 of 9 Old 12-26-2011, 05:55 AM
Powerstroke Techie
justinmix's Avatar
Does it try and start at all when after it sits overnight? Does it smoke at all? Or does it just crank and crank, never try to fire, and not smoke?
If it's trying to start and smoking that makes me think more of a injector related issue.
If it's not even trying to start then I'd be thinking more of a goofy electrical issue.
How long has this been going on? Did it just start to get worse since it got cold out? How long do you have to leave it plugged in before it will start?
post #7 of 9 Old 12-26-2011, 10:14 AM Thread Starter
It cranks and cranks doesn't smoke or try to start. I plug it in for a few hours and it starts no problem. When the cam sensor went out and the cam and crank sesors were replaced the issue started. When I took it home the very next day it happened. This was before the FICM was replaced, and the codes were cleared and update was done. Now the FICM was replaced it has the same issue. The guy at the diesel shop ensured me it was bad. Only thing is I still have the same issue with not starting when cold. Kinda irritating.
post #8 of 9 Old 12-28-2011, 01:40 AM Thread Starter
Well, thanks to Lyle at Bully Dog I have the program loaded back in. He was a great help! Now the truck goes back to the garage to get diagnosed. He is going to keep it overnight and wait for the cold start in the a.m. Hopefully he figures it out soon...
post #9 of 9 Old 12-28-2011, 02:01 AM
Other vehicle is an F250
Hank's Avatar
Glow plug relay good? Just a shot in the dark......
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
