No start day after oil change - Ford Powerstroke Diesel Forum
Old 12-24-2011, 09:01 AM
Exclamation No start day after oil change
Hi guys new to the 6.0L world traded in my 01 7.3L for an 06 6.0L back in April. Truck runs great. Currently has 60K miles. Last week the truck started having cold start issues. Morning temps here in So Cal have been in the low 40's. It would start up and idle really rough for 30-45 secs (pouring black smoke out the exhaust) then like a switch was flipped start running perfect no power issues no DTC's. My buddy told me it sounded like my oil was gumming up and suggested I change my oil. I changed the oil yesterday used Dello and Motorcraft Filter, also changed both Fuel Filters with motorcraft. Truck started fine yesterday after the work was done I drove it around town and ran some errands started up perfect. Parked the truck last night about 5:00pm and left t till this morning at about 8:15am tried to start it, nothing happens. She cranks and tries to fire but wont stay running. again no codes. The only thing new seems to be that i can hear the a clicking noise from the fuel filter on the frame rail on the driver side. I dont remember hearing that before? Any help would be great. Im starting to wish for my 7.3 back she had 285K miles without a single motor or trans issue. Im off work now till the 3rd so i have some time to work on her. thanks in advance
Old 12-24-2011, 09:16 AM
Illiana Chapter Director
Start by checking your FICM voltage.
FICM Voltage Test
Old 12-24-2011, 09:47 AM
thanks i will check that out when we get home (at the inlaws today) wouldnt the FICM going bad cause codes and/or running problems once it is started?? just curious
Old 12-24-2011, 09:55 AM
Not always, and if did set a code it won't always turn the check engine light on.
Old 12-24-2011, 09:58 AM
thanks appreciate the help i'll update when i know more just trying to keep her out of the dealer gotta save the mone
Old 12-24-2011, 10:01 AM
No problem. I know how that is
Old 12-26-2011, 10:41 AM
tested FICM today key on no start 48v cranking dropped to 25-27v.......looks like i have a bad unit any other underlining issues i should look at? is this repairable or should i just buy a new one from ford or another aftermarket company thanks James
Old 12-26-2011, 04:23 PM
I suggest Swamps Diesel with the 58v upgrade. Swamp's Diesel Performance
