HELP truck won't start - Ford Powerstroke Diesel Forum
Old 12-23-2011, 08:22 PM
My buddies 06 had the tbc fault show up and now his truck won't even turn over??? What could be the problem
Old 12-24-2011, 08:32 AM
For some reason my brain doesn't wrap around tbc fault.
Generally if the motor won't roll over, its either and electrical start circuit problem or a mechanical problem keeping the engine from being able to rotate.
Old 12-24-2011, 09:53 AM
information regurgitator
First, check the batteries. Low voltage when cranking can set that off (as well as eating your FICM).
Next, if anyone has been under the hood recently, and removed the FICM for any reason, loose plugs on the FICM will also throw that message.
Old 12-24-2011, 10:00 AM
Illiana Chapter Director
The TBC (Trailer Brake Control) fault isn't causing the no start.
Old 12-24-2011, 12:02 PM
Yea. That's wat my mechanic said. We checked all fuses and battery voltage and even got a scan tool but it wouldnt link up to the truck. We'll prolly end up towin it in Monday. Thanks for your help guys
