Another 6.0 Head Gasket question...... - Ford Powerstroke Diesel Forum
Old 12-22-2011, 03:06 PM
Ok so the other day i ran my truck pretty hard for about a one minute burst. When i got to where i was going i noticed steam coming out from under the hood i opened it and it was pukin some coolant outa the degas cap. When i got home i took it out of extreme street setting and put it back in stock. I havent had any more pukin problems since then. I have the liberator egr delete which keeps the egr valve in ... no block off plate. also has arp head studs. both were done at a dealer 2 yrs ago. the truck is an 06 6 speed manual and 87 thousand miles. i noticed when it was pukin that the coolant is a rusty color like you cant see thru it. do i have bad head gaskets or am i forceing coolant thru the egr valve? Also i noticed for the first time today that i didnt have any heat. then it started to work latter on.Any help would be aprecieated.
Old 12-22-2011, 03:43 PM
It sounds like you need to have it looked at for head gaskets and or heads.
Old 12-23-2011, 05:03 AM
JHK JHK is offline
I just had that happen, but the coolant in the degas bottle smelled like diesel fuel. one of my heads had a crack in the injector tube the other one had some hairline cracks around the exhaust valves. I went ahead and replaced both heads and head gaskets, and put in arp head studs. Now the other day when I started it back up it ran good for about 1 hr then when i went to test drive it I accelerated a little harder and it lost power and blew out lots of white smoke. I have been told that I did not get a injector seated well or I cut an o-ring on injector when i installed it. I did all the work myself. I got about $1800.00 in parts and did the labor on my days off and in the evenings. Good Luck
Old 12-23-2011, 05:11 AM
Powerstroke Techie
So you have the EGR cooler deleted but left the EGR valve in place? If so you might have the start of a head gasket issue. If you were still using the EGR cooler I would guess that the oil cooler is restricted starving the EGR cooler and making it flash boil, which would cause excessive coolant pressure.
If you don't have the EGR cooler then it can't be that. If your coolant looks rusty you have an issue there. I'm sure the oil cooler is plugged up, and probably the heater core.
You need to rig up a coolant pressure gauge and see how much pressure you're building. Also have EOT/ECT deltas. You are probably also going to need to do a VC-9 or Restore+ coolant system flush and try to get the rust deposits out of it. Do this before you replace anything or you'll just plug up your oil cooler again. Also a coolant filter system would be a very wise investment.
Old 12-23-2011, 05:22 AM
When mine blew I would still have pressure in the degas tank after it would cool. That is a free test. Also I had the heat issue. When I would be going to work i would have no heat until i would stop at a red light. When it would idel my heat would come back.
Old 12-27-2011, 02:54 PM
im gona be doing the gauge on the coolant line tommorow i just got back in town. Where can i get the restore+ from? thanks guys
Old 01-06-2012, 07:02 PM
so pressure in your degass lets say 8 hours after shut the rig down is a sign of bad head gaskets ??
Old 01-07-2012, 04:06 AM
It is a sign of combustion gases getting into the cooling system. It can only come from the egr cooler or head gaskets. Since your cooler is gone that would leave the heads.
Old 01-07-2012, 05:24 PM
yeah thats what i thought..well ive only puked one time from the degas so i think i might be in the clear as faras thing not being to badly messed up so but the heads are being done asap
Old 01-08-2012, 04:27 AM
mine only puked when i towed, but it always had pressure after driving.
