CEL EGR excessive flow - Ford Powerstroke Diesel Forum
Old 12-22-2011, 03:25 AM
Unhappy CEL EGR excessive flow
-Cleaned out EGR (First time in 71,000 miles, the thing was caked!)
-Broke loose as much gunk in the intake manifold that I could with a screwdriver and shop vac
-CEL comes back on within 10 miles of driving with same code.
-pulled it out and cleaned again
-This time I hear one loud click as if the EGR valve closed? Like it really was stuck open and flowing too much all the time. Sooo I thought I may have freed up the valve and it was working for about 25 miles, now back to the same CEL, EGR excessive flow.
Do I have a bad EGR Valve?
Owner at NAPA said he sells more EGR sending units or whatever the electronic part is...for $130, which is cheaper than buying the whole complete valve.
Any advice would be great! I have not had a problem out of this truck besides the FICM and do not really want to do an EGR delete.
If it is a bad valve any good prices out there? Money is tight as always
THANKS FELOW STROKERS!
Old 12-22-2011, 03:44 AM
Almostdunfukinwidit
Your valve was stuck open
Old 12-22-2011, 03:50 AM
Yes I believe it was stuck open but I still have a CEL that says egr excessive flow ...
Old 12-22-2011, 03:55 AM
Almostdunfukinwidit
Clear the CEL. If it comes back pull the valve and weld it shut
Old 12-22-2011, 04:57 AM
Weld it shut? Any pictures ? Cant really find anything on this topic of welding it shut
Old 12-22-2011, 05:43 AM
Welding it shut will still give codes with some engines. You will need a tuner to turn off the EGR system. When my EGR stuck open my engine ran like crap and also took out my turbo.
Old 12-22-2011, 05:47 AM
Truck runs great. Full power . It ran a ton smoother when I cleaned the egr valve .just trying to get it fixed properly
Old 12-22-2011, 05:52 AM
Ya need to either clean the valve really good or replace it. Iknow about short money but there is no simple fix with guaranteed results.
Old 12-22-2011, 09:00 AM
When mine stuck open they had to pull the intake manifold to clean it out properly.
Old 12-23-2011, 01:51 PM
Powerstroke Techie
Feedback Score: 3 reviews
there are lots of new factory EGR valves on ebay if you're looking to save a few bucks
