Heavy Smoker. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-21-2011, 10:29 AM Thread Starter
Heavy Smoker.
Hello all. I have a 03 F350SD, 6.0ltr. Smokes bad enough that driving is unsafe for anyone near me. Oil was down one litre and antifreeze leval okay. Smoke smeels sweet like cherries. Engine runs smooth with a ocassional missfire at idle. After reading here I took the intake manifold off and removed the EGR cooler and Egr valve. Cooler was dry and have the water part closed of and into a vacuum and is holding. Turbo has some oil on the inlet and the exhaust side is dry but sooted as was the EGR valve. When the truck was scanned it came up with codes PO269, PO272 and U0306. I had the FICM replaced two weeks ago. When I wiggled the injector wires at #3 and 4, the first two codes went away but remainder stayed after codes were erased. Any help would be great. Thanks Tony
tva13181 is offline
post #2 of 2 Old 12-21-2011, 11:04 AM
How many miles? Mods? Do you have a scanner of any kind (Edge Insight, SCT, Ect.)? What color is the smoke? When you removed the EGR cooler did you block off the up-pipe scoop? Does the smoke still smell sweet after EGR removal? Do you have oil in coolant/coolant in oil?
The U0306 code means that your ECM strat and your FICM strat are incompatible. When you had your FICM replaced who did it? Are you sure that is was programmed? If you buy one from Ford you have to have it programmed as they come without a strat. If you bought one from Ford and put it on yourself then this is probably part of your problem. If that happened then you need to go kick the parts man in the b*lls for not telling you that it had to be programmed.
P0269 and P0272 are cylinder #3 & #4 contribution/imbalance. I had the P0272 and Rev-X fixed it. If the injector is too far gone though, you will have to replace them two injectors. I would try Rev-X first though.
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
