6.0 gunk, A HOST OF PROBLEMS - Ford Powerstroke Diesel Forum
post #1 of 36 Old 12-20-2011, 09:54 PM Thread Starter
Not sure what too do, but one thing is for sure, I WILL NEVER BUY FORD AGAIN, once i figure out a way out of this thing.
Problem 1: started blowing smoke, loading up, no power then would clean out and go like crazy
problem 2: was overheating, flushed coolant then replaced the t-stat,
Problem 3: started burning thru coolant and overheating again
problem 4: oil pressure dropped, a few times, then stalled and wont start...
problem 5: its an 05, not under warranty anymore
what to do?
all ready replaced hubs,brakes,rotors,tires,shocks,injectors
and i dont work this thing that hard... its gotta go... 4x4 electric button failed for a while, spent a ton of $$ and its a total 05 lariat lemon
i guessing head gasket, injectors, oil pump, etc...
not too sure if i should fix or scrap it? what type of cost for this work?
fordsucksneveragain is offline
post #2 of 36 Old 12-20-2011, 09:59 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 903 Post(s)
Feedback Score: 6 reviews
You bought it used right?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 36 Old 12-20-2011, 10:07 PM
Long Member
TMAG6.0's Avatar
Welcome to the .org thats one hellofa first post
sell it and never look back
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click
to save a childs life.
TMAG6.0 is offline
post #4 of 36 Old 12-20-2011, 10:09 PM
novemberdelta's Avatar
Quoted: 3 Post(s)
Sounds like you probably didn't have any gauges?
2015 F-250 XLT
Fisher 8.5' Extreme V Snow Plow
novemberdelta is offline
post #5 of 36 Old 12-20-2011, 10:12 PM
RIP Cam!
Quoted: 903 Post(s)
Sounds to me like another person who bought something they didn't research well enough.
post #6 of 36 Old 12-20-2011, 10:14 PM
Quoted: 3 Post(s)
Yup..
2015 F-250 XLT
post #7 of 36 Old 12-21-2011, 02:26 AM
Powerstroke Techie
justinmix's Avatar
If you overheated it multiple times and ran it till it wouldn't run anymore then it's probably toast.
More then likely you melted down the oil filter stand pipe. This usually happens when oil temps get over 300 degrees. You have now toasted all the everything in the engine that uses oil, like rod and main bearings, lifters, rocker, HPOP, injectors, turbo. Basically everything. Not to mention it probably put melted plastic thru the oil galleys now.
Pull the oil filter and look at the oil filter standpipe and see how it looks. If it's melted at all, congratulations, you know have a big pile of scrap for an engine. I would replace it with a junkyard engine.
Saddest thing about this is it was probably all from a ruptured EGR cooler, which you could have replaced with a delete for $150.
Hope you get it figured out.
justinmix is offline
post #8 of 36 Old 12-21-2011, 12:50 PM
Frozen Redneck's Avatar
Gotta do your research man. Nothing wrong with Ford, 45 minutes on the internet, you probably could have learned the cause and also how to fix everything that went wrong, or done some research prior to your purchase and made a much more educated purchase, or not bought based on the obvious signs of what was wrong with it. Sell it and get hosed, it's not worth much now, but somebody out there, or somebody on here will be more than happy to take it, put a motor in it and have a heck of a nice rig. All trucks are lemons if not maintained, diesel's aren't turn-key toys, especially not 6.0's.
Will
Dodge V-10 with a cracked head
Originally Posted by ol_Blue97 View Post
quick.... there is a fight in the performance section!!!! hahahaha i feel like a high school kid
Originally Posted by 351fifty View Post
just a bit large lol, but thanks bud
Frozen Redneck is offline
post #9 of 36 Old 12-21-2011, 01:09 PM
f350powerstroke's Avatar
New gaskets,coolers? If u melted ur motor go buy a reman, make sure u have new coolers and get an edge insight to observe ur deltas
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
post #10 of 36 Old 12-21-2011, 01:12 PM
kingranch89's Avatar
you come on here wanting help with a user name like that and bashing ford. good luck buddy change your attitude
2007 F250 king ranch 6.0 powerstroke
SCT w/ custom tunes from innovative
5" mbrp exhaust
Studded and EGR Deleted
FINALLY SOLD!!!!
on to the next toy
kingranch89 is offline
Tags
head gasket
