what should idling pressure be?
its running about 20 psi at idle. i have noticed a little bit of a surge at idle lately and a few hiccups when driving. im not getting any codes. also i noticed a little haze of blue smoke when idling when truck is warm. any ideas?
Fuel pressure?
64 at idle
at idle boost should be zero.
You're asking what psi should be at idle. I'm asking what are you talking about? Fuel, HPOP, boost, oil?
map sensor might be going crazy. 64 isnt possible at idle
sorry oil pressure. i have a regulated return i set to 64
It takes 500 psi from the HPOP to start the truck, so I can't imagine it being less than that at idle. Low pressure would be considerably lower.
yea ipr is reading good. truck starts and drives. i wondering if this an early stage of something going wrong. it seems like the truck is quieter at idle.
ICP should be about 580 psi @ idle with the engine up to operating temperature in PARK or NEUTRAL on any late-build '04 on up to '07 truck. '03 engines are usually about 620 psi if I recall correctly. IPR duty cycle should be between 21 to 24% at operating temperature on all engines, idling.
