hey guys, i blew my head gaskets last weekend now im getting ready to tear down and rebuild
truck is an 05 with 114000kms (bought it with 104000 )starting of with that kit eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices Black Oynx 18MM Dowel Head Gaskets (2) Black Oynx Gasket Kit Black Oynx Exhaust Manifold Gaskets ARP 250-4202 Head Stud Kit EGR Delete Kit with Turbo Up Pipe Brand New Ford Oil Cooler (includes screen) Full Set of Injector Orings Turbo Gaskets and Hardware Ford Fuel Pressure Regulator Upgrade Kit 8 Dual Coil Fast Heat Glow Plugs Oil Filter Rev X Oil Additive my glow plugs are also gone and injectors stick abit my questions are, torque values??? anyone have them or have pics anyone ever just drill out the OE 6.0 banjo bolts? anything else that should be done while im in there? thanks kevin |
PM me your email and I can send you all the torque spec. Looks like a good list of parts. From what I've read the Black Onyx head gaskets need a very clean surface to bond to both heads and the block.
also head are going the be decked if warped or if theres corrosion if their straight (doutb it tho, 95% arent from the factory) ill have the skimmed to get them as clean as possible |
I'd buy OEM head gaskets.
PM sent. Be sure to have them mag'ed. I had 2 cracked heads on mine
OEM Head Gaskets!
thanks guys,
got all the torque info how about the sequences? center outwards? or both ends inward??? anyone got a diagram of the proper sequence? being 19 i really cant afford to fk it up! thanks kevin |
I take it you're talking about the heads? The ARP kit should come with the torque sequence. If not go to their website. I know you start on the inside, its a cross pattern and work your way out.
Sent from my android phone using autoguide.com |
ok, everything is finaly here and ready to go
head were milled 8thou, now nice and flat all parts cleaned and inspected and anything else to look for or i should do while im in there list of things done heads milled blue spring mod drilled banjos new boots (3 of them were cracked and or blown) new balanced turbo center (old one had something go threw it ![]() ![]() arps glow plugs new elc coolant coolant filter new oil cooler new torque wrench |
