Hey everyone, I thought someone here could perhaps lend a hand in narrowing this leak down.
I noticed what was a leak flowing down the front of the engine and in my experience that meant the waterpump had gone. As such I replaced the pump and before I bolted everything back on I decided to check and be sure it was going to hold coolant. When I put coolant back in the engine it streamed out just as much as before. The hard part is, I can't see where the leak is coming from. It looks to be behind the pullies somewhere. My next step is to take off the crank pully and any other pully in the way to see if I can locate the leak. My question is, is there anything right behind there that could be leaking? On all the engines I have rebuilt in the past (351C, 350, 440) all the frost plugs have been on the side. Is there one on the front on the 6.0? Also, looking at the 6.0 bible I noticed there was perhaps a flat steal gasket behind the waterpump region. Has that ever leaked on people before? Thanks Ryan
No ideas eh...
What was not bolted on when you replaced the coolant? Does it leak with the engine off as well? Heater on/off?
Most likely the o ring that seals the coolant passage in the intake to the front cover... It will run down the front of the engine maybe more towards the passenger side.
Sent from my android phone using autoguide app |
It leaks running or stopped. The test I did at the end was with the engine off. |
I think this has potential, but the coolant leaked out to the point that I was able to remove the water pump again with no coolant leaking out. To me that makes me think that the leak is perhaps below the pump, but I have to double check the flow path on the 6.0 bible to confirm that.
Might be a cracked front cover. You are sure the o-ring is on the waterpump?
Ya, water pump went on correctly. I am thinking the front cover may be at fault here.
Might wanna check around the thermostat that's where my leak was
Sent from my SCH-I500 using AutoGuide.Com Free |
