code p2262
I just finished a bunch of work on my 04 f250. Oil cooler & egr cooler went out so I replaced those, added gauges, coolant filter kit & fuel pressure blue spring update. I got the truck running last weekend & I have no power
the cel light is on & its throwing a p2262 code, turbo boost pressure not detected/ mechanical. Any ideas? I was told probably an air leak? I've triple checked all the turbo connections everything is good. I really need some help please! I've got to get this thing running this weekend, thanks a lot!
Well I checked the map sensor hose & that's not clogged. Then I pulled the cat off drove it & it's still lacking power & the code is still there. Anyone have any ideas I'm at a loss. Don't know what to do??
Check the connection where the y pipe mates with the turbo. This connection must be perfect. Do not rely on the v clamp to pull it together.
