Another White Smoke Thread. - Ford Powerstroke Diesel Forum
Old 12-16-2011, 12:53 PM
So, about a week or two ago, I was driving down the highway, minding my own business, when out of nowhere a puddle of water jumps in front of me. Well, to be fair, it was raining... but anyways.
I hit this puddle of water and let off the gas, so as not to swerve off the road and kill myself. Once I am clear of the puddle, I go to accelerate. Whomp whomp whomp, chug chug chug, no power. I try again. Same thing. Then I notice a small cloud of white smoke. "WTH?!?!" I exclaim, immediately pull of the side of the road and shut her off. Ever since then, off and on, she will become entirely un-driveable, no power, bogs herself out, and puffs white smoke.
What the heck do I have here?
I JUST pulled the EGR valve before posting this thread, and it was caked on the inside, but it wasn't "wet." It wasn't bone-dry, either, but certainly not what I would consider moist. Plus, I don't really know what the soot should be like... charcoal, oil paints, or somewhere in-between. I've had several people use their noses to check the smoke's scent, not a single person has described the smoke as "sweet" smelling, even when I ask, "does it smell kind of sweet, like anti-freeze?" They all say it smells like straight-up diesel exhaust, and I'd agree, though my sense of smell isn't the greatest.
So, to recap:
White smoke with almost complete loss of power, under load.
EGR Valve was not Gooey or Steam-cleaned, but was not bone-dry, either.
White smoke does not have a discernible "sweet" smell to it.
No Check Engine Light.
No loss in Coolant level, Oil Level, or Oil pressure, that I can tell.
Please help. Please.
Old 12-16-2011, 02:50 PM
anybody?
Old 12-16-2011, 03:31 PM
information regurgitator
Check the egr by parking the truck on a decent hill nose down, pull the valve and leave it like that overnight. Check the bottom of the hole in the morning for ANY wetness. The soot should be dry packed powder. Not greasy in any way.
Find anything other than that and the egr cooler has failed.
You might also want to clean the egr valve while its out using carb cleaner. A sticking egr valve could also give you the symptoms you describe.
It can also be caused by a failing ficm or injector stiction, but those present themselves when the engine is cold.
Old 12-16-2011, 08:57 PM
So, newb question, but I HAVE to drive this thing home on tuesday, and back on the 2nd of Jan. (400 miles one-way). What is the danger of driving with a leaking egr cooler, if in fact that turns out to be what it is?
Old 12-17-2011, 12:28 AM
I'm no mechanic, but I been rambling thru this site for a while and have read just about every EGR post on here. I believe I'm right about this, if not somebody will correct me. The egr cooler is there to cool your exhaust gases, when it fails the coolant will mix with the exhaust gases and be taken into the intake, it may not do much damage at first but if ignored over time it can get hot enough to stretch your head bolts and blow your head gaskets, u should also be loosing coolant thru your exhaust, which means it will go thru your turbo, and from what I hear it can really mess your turbo up. also one of the main reasons a egr cooler fails is because of a clogged oil cooler. If the oil cooler continues to clog it can rupture then u will have a big mess with oil mixing with your coolant, then u got oil all in your cooling system. If it were me I would make sure my egr and oil coolers were in top notch shape before taking off on a 400 mile trip. Hope this helps.
Old 12-17-2011, 09:49 AM
Firefighter Member
when you pulled the egr out did you clean it to new look? If so one test is hold the end to a light......can you see the light through the valve, sometimes something will get cought in there holding it open....sometimes....which will make it do what your discribing. My egr valve was becoming stuck open so I found a used one for $50 and fixed it. Another thing is when you have the egr off start your truck up with your foot to the floor, this will clean your egr out. What you are discribing sounds exactly what I just went through. Try the starting the truck up and the light test on the egr and post back to let us know whats going on.
By the way all information I am giving to you was told to me by a mechanic who has worked on 6.0's since the day they came out. He works on all of ours for the fire rescue ambulances every day so I trust his word....and it worked for me.
Old 12-17-2011, 02:52 PM
Yes, I've read about the gases stretching the bolts, but there's really nothing I can do other than drive it. I don't have another vehicle currently.
I'll try that out when I get a chance to, I'm afraid to take the valve back out until I can get new o-rings. The ones that were on it looked pretty done-in, but I didn't have any replacements on hand, so I just kind of had to go with it.
Damn.
Old 12-17-2011, 03:06 PM
Be a whole lot cheaper to rent a ride versus replacing head gaskets....
Old 12-17-2011, 04:16 PM
Powerstroke Techie
Feedback Score: 3 reviews
see if you can pull any codes out of it, sometimes the check engine light won't illuminate with EGR issues.
with the key off unplug the valve and see if it runs without it. if it's still doing the same thing you may have an injector issue
Old 12-17-2011, 06:03 PM
Wouldnt running it without the EGR valve hurt something?
