2003 6.0 no start...hpop? - Ford Powerstroke Diesel Forum
Old 12-15-2011, 05:47 PM
ok guys i have a 2003 6.0 im having starting issues the truck died on me while driving down the free way i have replaced the cam sensor and crank sensor. still had the same problems would not fire. it fired up with a gas rag and idled fine. i pulled the FICM pulled it apart and the circut board was burn up. i replaced it 2 times and got bad FICM's. we thought it was the HPOP but its idles fine. now with the ne FICM i have no injector cycling what so ever. we took it to ford and they said it was the HPOP and not the FICM and clearly the FICM was toast!!! guys this is my first 6.0 and im not working because of this!! so please any info will be greatly appreciated
Old 12-15-2011, 05:50 PM
What do you mean injector cycling? Like when you turn on the key the injectors click but without cranking it over?
Old 12-15-2011, 08:58 PM
my burnt one did but new one doesnt and the dealership said its my hpop with no diagnostic at all
Old 12-16-2011, 04:15 AM
Then don't go back to them. That injector ticking before and after running the motor is the latest flash to help stiction, that's all. The turbo vanes cycling is part of that flash too. Don't take it back to that dealer.
Old 12-16-2011, 04:54 AM
Powerstroke Techie
So, it idles fine but won't rev up? Or now it's not starting? I'm confused....
If it's starting and idling then the HPOP is at least making some pressure. Any codes logged?
