6.0l questions, bad test drive
at a dealer,
drove an 04. f550 75Kmi a 7 out of 10 barely any rust even on the frame and leaves. It needs either an egr cooler or headgaskets. The ect and eot temps stayed within spec, but when it hit full boost, 33 psi, it lost power and started blowing white smoke... First instinct is to run. second thought is damn that truck is in really great shape minus the motor which is about to go through the shop and have everything replaced... how long does this fix last? and if I get it with all new parts what are the chances of keeping it running well. dumping the ford gold for ec-1. I would say installing parts like bulletproof egr and such is possible, and If it is neccessary I may be able to talk the dealer into installing them.. Need some opinions and reasons. Do I keep running? I want experience stories. |
33 psi of boost sounds high to me. Normally it's around 23-27 psi max. If it's really getting 33 psi stock then something is wrong with the turbo. If they have been running around with it over boosting then it could cause issues with the engine or possible head gasket problems.
Did it puke any coolant out of the degas bottle? Do you see any signs of dried coolant around the cap? I would check coolant pressure under load and see what's going on. If it looks more like it's a EGR cooler issue I would install a EGR delete. Guess it depends on how good of a deal it is. Are they offering any sort of warranty with it? |
I would either make them put OEM HG's, ARP studs (your gonna have to buy them), Egr delete or BPD egr cooler, (you're probably gonna have to buy also), and clean the turbo. Sounds like the veins are sticking b/c 33 psi boost is high, especially stock. Then I would negotiate on price as you had to spend all that cash to get it running again.
Oh yea get them to throw an oil cooler in there too as that is probably what caused the HG failure. Also 33 psi could have caused it. |
They were running compression tests on it the last I spoke to them. See what the findings are. EGR is junk. Believe oil cooler too. I know the manager. he certainly has to make money too but it helps. and a 12/12k warranty, Ill keep ya posted. Keep the suggestions coming.
I would not let them put the OEM EGR cooler back in there.
current standing and could use some advice.
Dealer is will to foot the labor bill to tear down the engine and do an egr cooler, oiler cooler, head studs and gaskets. The only "required" work right now is the egr cooler. Ect and Eot stayed with 15* when I had it... compression tests came back fine, so head gaskets aren't considered necessary. from BPD the total on my end comes to just over 4k with shipping. If I drive the truck home for 20,500. I'm into it for 25k. Is the truck done? Is it worth that kind of money? I would sure hope I will no longer be seeing any issues and with routine maintenance I am going to be getting plenty of power for the next 200k. any thoughts? |
If you can see if you can have them throw on a delete for the EGR. With the Ford IDS on these truck I have personally seen boost levels of 32-34 on a stock worked hard truck with a trailer on it. Stock gauge reads 25
well I bought the truck
Dealer is putting in BPD Egr cooler BPD oil cooler kit ARP head studs new head gaskets. There is a whole long list of little bits here and there they are replacing. I am not fond of the idea of the delete. Especially when you dont have to you can simply put in a proven cooler. Should be sweeeeeet. |
are you from maine?
Congrats on the purchase. Enjoy your new truck!!! |
