lack of power ? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-11-2011, 01:02 PM Thread Starter
lack of power ?
So I finally got my truck back together, I had a clogged oil cooler. Changed that, put a new bulletproof egr cooler, coolant filter kit, new fuel pressure blue spring & hardline turbo oil supply. I got it started up last night & it seemed to be running fine but one thing that I noticed was at first there was a little smoke comming from somewhere near the intake manifold. It went away after letting it run for a few minutes. I went for a drive this morning (too many beers last night ) the truck lacks power & white smoke or steam is coming out of the tail pipe. I think its steam it dissipates very quickly. Anyone have any ideas? Thanks in advance for the help!!
ahren111 is offline
post #2 of 6 Old 12-11-2011, 01:33 PM
Coolant got in the wrong spot when you were working on it and just needs to burn out.
Bad EGR cooler from BPD ( pretty unlikely, but could happen )
Bad head gaskets
As far as the power loss, any codes etc? What year and mods? Look for leaks on both sides of the turbo.
HAM_RADIO_MAN is offline
post #3 of 6 Old 12-11-2011, 01:44 PM Thread Starter
Its a 04 with 120k miles. No mods all stock. I just installed isspro gauges coolant temp & oil temp. The coolant temp was running around 160 on a short drive about 1 mile. Im not able to read the oil temp yet cause they sent me the wrong wiring harness with the gauge the right one should be here monday or tuesday. I'm not loosing any coolant if it was the head gaskets I'd be losing some right? The check engine light is on but I don't have any way of reading it today. I should be able to borrow a scanner from a friend tomorrow.
ahren111 is offline
post #4 of 6 Old 12-11-2011, 01:52 PM Thread Starter
The check engine light was on prior to my repairs, excessive egr flow was the code that came up. I never cleared that code is it possible the light is still on is it because I never cleared it?
ahren111 is offline
post #5 of 6 Old 12-11-2011, 07:29 PM
Did your old EGR cooler fail? If so you are probably still buring off the coolant that is in your exhaust
Former 6Leaker owner
Newman is offline
post #6 of 6 Old 12-11-2011, 07:42 PM Thread Starter
Ya the old one did fail. Burning off the coolant in the exhaust would explain the steam coming out of the tail pipe but what about the lack of power? I looked at the turbo all the connections look good.
ahren111 is offline
