6.0 po273,po279 codes,no power - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-10-2011, 12:50 AM Thread Starter
This is my first post and I would like to thank everyones post I have read in the past to help me troubleshoot my 7.3 truck. I have a 2004 that I bought brand new that turbo went out @ 8300,27000,&39000 miles,Egr cooler@42000,Egr valve@45000.I make sure I change all filters&fluids every 5000 miles I'm at 54000 miles now.My problem is I loaned the truck to my brother to pick up a boat called me up and told me the truck ran fine there but would not pull the boat over 35 mph up grade and then died and wouldn't restart.had it towed home,I pulled up 2 codes po273,po279 low voltage injectors 5&7.Changed fuel filters,checked ficm voltage 48volts key on and running.I know I got some bad fuel somewheres cause there was some chunks of rust in the primary filter.just replaced the fuel pump for precaution still no change could it be the ficm,the pcm, or worse the injectors? Anyone ever had this problem?
Randall7.3 is offline
post #2 of 3 Old 12-10-2011, 02:16 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Here is a list of things to go over.
Troubleshooting a No-Start condition
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 3 Old 12-10-2011, 05:31 PM Thread Starter
Good info,I need to find someone with a good scanner to check injectors,I just hope it's the FICM,thanks again for the help and I will post what the results are as soon as I can get it dialed in
