2005 F350 with no throttle response... - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 15 Old 12-09-2011, 09:00 AM Thread Starter
LOW96HB's Avatar
My 2005 F350 6.0 has a problem I can't pinpoint. you can be driving along and have to let off the throttle to make a turn, redlight or just whatever and ometimes when you get back on the throttle it won't go. You can go as far as to hold it to the floor and nothing but idle or even a slow idle. If you hold it to the floor it will slowely start to pick back up. The truck has only died once, but it just gets a slow idle..... Anyone had this issue before? Thanks Scott
steve" likes this.
KEEP HONKING, I'M RELOADING.
2000 F350 Lariat crew cab 4x4 7.3L
SuperChip ( plug in type )
Banks Big Head wastegate
LOW96HB is offline
The Following User Says Thank You to LOW96HB For This Useful Post:
steve" (12-22-2013)
post #2 of 15 Old 12-09-2011, 05:43 PM
Do you have any codes? This sounds like the sensor on the gas peddle is getting flakey.
See the tech manual PDF in my signature there is a page in there that explains there are 3 tacks on the gas peddle sensor and if they are out of agreement all it will do is idle. This is my best guess. You might also check the connector.
HAM_RADIO_MAN is offline
post #3 of 15 Old 12-09-2011, 05:48 PM
This may not be your problem ,but with the very limited info you have provided This is my best guess. Any trouble codes or other info woul dbe very helpful.
post #4 of 15 Old 12-09-2011, 06:20 PM
My 6OH Hates Me
mudrunninpig's Avatar
Quoted: 24 Post(s)
I agree Ham, OP do you have any codes or a wrench light?
Mike
"The Iron Pig"
mudrunninpig is offline
post #5 of 15 Old 12-09-2011, 06:35 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
Sounds like a TPS sensor going bad. I'd replace it, and see where that leads!
2005 Lariat CCSB F-350 SRW
300,000 miles and going strong
Exterior
12" fabtech lift with 40" Xterrain's on M/T classic locks, Adjustable track bar, Bilstein 7100 reservoir shocks
Performance
Edge juice/attitude CTS, SCT with ID tunes, Snow meth. injection, Diamond eye 4" exhaust, 03 turbo, ARP studs, Sinister coolant filter
Interior
2010 stone seats/console, pioneer avic d3 with backup camera/bluetooth
Misc.
Viair 450c compressor, dual 2.5 gallon tanks, air horns rated @115db
dazdillenger is offline
post #6 of 15 Old 12-10-2011, 03:53 AM Thread Starter
LOW96HB's Avatar
Hey thanks guys..I will check into this over the weekend and see where that leads.. Thanks again. Scott
LOW96HB is offline
maldune (09-22-2014)
post #7 of 15 Old 12-10-2011, 04:29 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
yes an accelerator pedal would be a good place to start, it's not that uncommon
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #8 of 15 Old 12-10-2011, 07:02 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
I had the same issue when my ICP sensor went out. Wouldnt happen all the time but it would happen a lot. After I replaced it never happened again.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #9 of 15 Old 12-13-2011, 05:15 AM Thread Starter
LOW96HB's Avatar
The truck is at the shop now, I gave him this info and he said that was a good place for him to start. I will give a responce as soon as I get the truck back. Thanks guys.
LOW96HB is offline
post #10 of 15 Old 12-13-2011, 05:33 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Cool, hopefully its something simple. Also, get rid of the K&N filter and save yourself a turbo blade.
WarChild is offline
The Following User Says Thank You to WarChild For This Useful Post:
JER-1 (07-22-2016)
