6.0L oil Cooler re-assmebly problem - Ford Powerstroke Diesel Forum
post #1 of 24 Old 12-08-2011, 07:19 AM Thread Starter
So, I followed the advice and replaced my oil cooler after temp deltas of >20 degrees were seen. Now I am putting everything back together and I have this spring which I can not remember where it goes. Need some help from the experts here since my manual is not much help at all for showign exploded views.
I have attached an image of the spring below. (I think)
Any ideas?
Thanks guys,
Jason
sailopus is offline
post #2 of 24 Old 12-08-2011, 07:30 AM
F250SixOH's Avatar
Not sure but srmastertech on youtube has videos of him rebuilding an oil cooler. Maybe watch it and see where it came from? Hope that helps.
F250SixOH is offline
post #3 of 24 Old 12-08-2011, 10:21 AM
Not recalling any springs in the oil cooler. Are you doing a blue spring upgrade by chance but that doesnt look to be the right length for a fuel pressure reg spring either.
justa03 is offline
post #4 of 24 Old 12-08-2011, 10:23 AM
Could be the spring from the top of that standpipe in the oil filter housing if it was broke or is broke?
justa03 is offline
post #5 of 24 Old 12-08-2011, 10:45 AM Thread Starter
I need to do the blue fuel spring upgrade, but that is a much smaller spring.
Would this spring be inside the oil filter standpipe? What is that for?
sailopus is offline
post #6 of 24 Old 12-08-2011, 11:00 AM
Quoted: 6 Post(s)
Might be the spring for the oil filter bypass in the top of the black plastic tube in the oil filter housing. If the top of that doesnt have a little spring loaded button then you need to replace that standpipe in the center of the oil filter. If the button is missing then the bypass is broke.
a2elvis is offline
post #7 of 24 Old 12-08-2011, 11:05 AM Thread Starter
Ok, thanks. I will go take a look. Anyone have an exploded view of the oil filter assembly? And the fuel filter would be good. I want to make sure I have the fuel regulator spring onthe correct side of teh brass fitting.
sailopus is offline
post #8 of 24 Old 12-08-2011, 11:15 AM Thread Starter
Nope, I still the the spring inside the oil filter standpipe with a black ball thing on the top. So that is not this missing spring.....
Any other ideas?
sailopus is offline
post #9 of 24 Old 12-08-2011, 11:57 AM
Where did you pull the spring from? Outta the reservoir?
justa03 is offline
post #10 of 24 Old 12-08-2011, 12:04 PM Thread Starter
That is the problem....I don't remember where this spring came from. I should have had a better system for keeping track of where the parts were coming from instead of putting them all into one box.....lessons learned!
sailopus is offline
