Small coolant leak. - Ford Powerstroke Diesel Forum
Old 12-07-2011, 10:22 AM
Small coolant leak.
I have a small coolant leak, almost a weeping when the block is cold above the #7 cylinder at the rocker carrier/head seam. Any ideas where and why its doing this? Possible fixes?
Old 12-07-2011, 10:42 AM
IF the leak really is in that location, I am thinking head gasket. If it is not there,I would look at the EGR to oil cooler hose connection.
Old 12-07-2011, 11:33 AM
If it is the head gasket, wouldn't the leak be lower then the rocker carrier? For reference, it looks like it's coming from right below the #7 GP buss bar connection. How likely is it that the GP cup is cracked? That's the only place where coolant flows in that area if I'm remembering correctly.
Old 12-07-2011, 03:53 PM
Nightly bump TTT
