Cold Start??? - Ford Powerstroke Diesel Forum
Old 11-30-2011, 01:23 PM
Cold Start???
Hi everyone i'm new to the 6.0 diesel and need some advice on the starting issue i have. I have a 2005 f550 with 140000 miles on it. I go to start it in the morning and i have to hold the key for pretty long to get it to turn over but after the first time it will start up no problem. Also when it high idle how high should the rpms be? It just doesnt sound like its high enough compare to my cummins truck.
Thanks for the help
Old 11-30-2011, 03:35 PM
Do you have a way to monitor FICM Voltage, or battery voltage? Either one of these is where I would probably look first.
Also, depending on temperature outside, high idle will be anywhere from 800-1100 or so, at least that's how my truck is. However, I have also modified mine for 1200rpm high idle, controlled with one of my upfitter switches.
And also, A 6.0 is not a cummins, so beyond diesel fuel, no comparison! Lol!!
2006 F250 Lariat FX4:
MBRP 4" Turbo Back Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle Mod
Dieselsite Coolant Filter
58v Swamps FICM
SCT w/ Matt's SRL Tune
