03 6.0 fuel pressure
ok, put a gage on the test port of the fuel bowl to see the current pressure.
that day it was 35 psi,so i figured i had a bad pump, bought a brand spanky new one. and now the fuel pressure is 20 and holding. the truck runs great! but will not produce anymore tha 20 psi. what could i be missing. New filter, stage 1 fuel lines. fuel crossover line in the back NO LEAKS im stumpes! anyone else have this prob or simular? |
Upgrade to the blue spring fuel pressure regulator. It raises the pressure to about 70, much better for the injectors, and takes no more than 45 mins of your time.
You probably don't have a problem its just the spring gets weak Last edited by roche837; 11-29-2011 at 08:11 PM. |
Ford Powerstroke Diesel 6.0l Fuel Pressure Regulator Blue Spring | eBay
Ford Garage will want at least double |
im sorry, i forgot to mention that is in there too.
got it last week as an option. i useually get the prroblems fixed but im on this one for 22 days now and im tired of not getting it |
fuel filter or filter(s) with that many upgrades im sure you replaced both. are they motorcraft filters? |
fomoco pump and filters ...thats whats getting me. right stuff wrong outcome
Quite sure you have already double checked but maybe take apart the fpr and make sure everything is seated correctly? Other than that possible your gauge is incorrect? Try a different gauge just to confirm?
