I have been pulling my hair out on this one:banging: I have a 06' 6.0, and it starts fine cold and hot, but while driving it doesn't seem t have the power it should. It is compleatly stk. I noticed the boost gauge doesn't move much at all until about 2000-2200rpm. I also have AE and there are no codes. Cyl cont and fuel pressure looks good also. All filters have been changed. I was monitoring the ipr and found that it would only get to about 44%. I changed it manually and even when i commanded anything over 40% it wouldn't go any higher. Is this normal or is my ipr faulty? Anything else i should check. Thanks
does you truck smoke at all? mine has lost some power recently and its blowing smoke out sometimes off the line. I think the veins are stuck on the turbo. I am going to pull my turbo off and give it a good cleaning and see what happens. Maybe you could try that.
ya it smokes a little but not much. I opened and closed the veins with AE and heard a significant change in tone so i think they are working. Im thinking i have a hpo leak.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
