I have an 04 6.0, I had coolant leaking out the cap of the degas bottle, so I went and replaced the cap, and now its not puking thru the cap, but its leaking somewhere on the what I believe is the heater core hose, its the one that runs from the top port of the degas bottle, and goes along the fire wall. its leaking enough where I smell is. Any ideas as to why this hose would be leaking, could I need head gaskets done again, also I have an egr delete.
I have had that same issue. It turns out that hose was rubbing on one of the corners of the FICM. I replaced the section and routed it a bit away from the FICM. No more problems...
I cut the hose at the pinhole, bent the solid section a bit and installed a hose splice. The added tiny bit of length and the bend gave me about 1" of clearance at that point.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
