put new stand pipe and dummy plugs in today and torqued oil rail bolts to 15 lbs and I see on here they should be 10 lbs should I pull valve covers and back them off or leave it alone
They'll be fine. The spec is actually 120 in.lbs, which is 12 ft.lbs. Most torque specs give you a +/- of 1 or 2 ft.lbs any way. Now if you said you only did them at 5 ft.lbs then I might say pull them off and tighten them up more. But since you're over the spec you are fine.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
