? on the 7 pin ficm - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-24-2011, 06:05 PM Thread Starter
? on the 7 pin ficm
Hello I was wondering if anyone could give me some info on the 7 pin ficm.I have read that I need to put my volt meter on the top screw on the 4 screw row.I put my meter on there with the key switch on and got no volts.Even when trying to start,I got no volts on that outer screw.What does that mean and is it ok to test the other screw terminals.My truck is in a no start condition....
Strokemy6.0 is offline
post #2 of 9 Old 09-24-2011, 06:16 PM
capcalvin's Avatar
Top right closest to firewall.
'03 F350 6.0 CC dually lariat 4x4
Autometer gauges:
Pyro, boost, fuel pressure
Edge insight cts
Bulletproof EGR cooler (Blocked off)
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Exhaust: MBRP 4" cat back with delete pipe
SCTx3 Tunes by Innovative and Gearhead
Swamps 58v FICM
High idle mod
SRW front wheel conversion
ARP head studs
capcalvin is offline
post #3 of 9 Old 09-24-2011, 06:31 PM Thread Starter
Thanks I checked that screw and got no volts with the key on and while trying to start.I've tryed testing multiple time and i get no current on that one.Since it cut off in my driveway and hasnt started back,I havent heard the injectors cycle when turning the key to the on postion.I can get it to fire on a quick shot of ether or a rag with gas.It will run on the fumes and then die.I have had a couple of blue smoke puffs sometimes while trying to start.I have 2 new 850 cca batteries and a new ficm relay..Any ideas....
post #4 of 9 Old 09-24-2011, 06:54 PM
capcalvin's Avatar
ficm fuse? Sounds like your ficm might be toast. Not sure what else would cause no ficm voltage. Maybe someone else will chime in here.
Autometer gauges:
Edge insight cts
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Swamps 58v FICM
High idle mod
ARP head studs
post #5 of 9 Old 09-24-2011, 07:02 PM Thread Starter
Where is the ficm fuse located??
post #6 of 9 Old 09-24-2011, 07:21 PM
capcalvin's Avatar
There is a 10A fuse in the same location as the relay you replaced in the engine compartment. Not sure if there is another one in the fuse box in the cab or not. Check the owners manual. You should be getting 12V +/- on one of the 7 pins on the ficm. I don't remember which one is the logic power, but if your getting 12V to the ficm and nothing out, I'm guessing you've found the problem.
Autometer gauges:
Edge insight cts
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Swamps 58v FICM
High idle mod
ARP head studs
post #7 of 9 Old 09-24-2011, 07:29 PM Thread Starter
There are 2 fuses in the engine compartment,I believe one was a 20 amp and other was a 10amp.I have power on the 20 amp fuse and no power on the 10 amp fuse..If that 10 amp fuse is the ficm and it has no power but the fuse is good.what should i look for next??
post #8 of 9 Old 09-24-2011, 07:46 PM
capcalvin's Avatar
The 10A fuse is the ficm logic. Also check fuse #103 in the fuse box inside the cab. This is a 50A fuse for the ficm power.
Autometer gauges:
Edge insight cts
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Swamps 58v FICM
High idle mod
ARP head studs
post #9 of 9 Old 09-24-2011, 07:57 PM Thread Starter
Should I just pull the 50 amp fuse out and test the connectors or should I be able to tell just by looking at the fuse???I know when i checked the 10 amp fuse under the hood it had no power.Would it be ok to test the other screws on the ficm with the volt meter.I figured when my truck cut off that it couldnt be a internal motor part.I guess im on the problem and now i need to figure out why that top right ficm screw has no power.And also find out why that 10 amp fuse under the hood does not have power.
