2004 f250 no start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-12-2011, 03:35 PM Thread Starter
2004 f250 no start
I was driving down the road and just died. The codes were p0670 and p2617. And I had a bad battery. R2 battery and ckp sensor. The ckp sensor code went away. Then I got the icp code. Checked the wiring on the icp, found a burnt wire and the platsic clip is broken. Replaced the clip and wires. Still no start. Is there a fuse I'm missing? Tested the icp before I replaced the wiring and and was getting power but not putting anything out. What to do now??
bullr is offline
post #2 of 4 Old 08-12-2011, 04:34 PM
Send a message via AIM to PowerstrokeTech82787
I would start investigating the sensor and pigtail, then do the high pressure oil leak air check
PowerstrokeTech82787 is offline
post #3 of 4 Old 08-13-2011, 09:12 PM
Tri County Motorsports's Avatar
I 2nd that sounds like definately high pressure problem. Check icp pressure.
2008 F-450 4X4 ,4 Inch S.S Flo Pro,H&S Mini Maxx hd300
Tri County Motorsports is offline
post #4 of 4 Old 08-14-2011, 12:19 PM
I changed the oil, still doesnt start, oil pressure doesnt come up while cranking either
CHEECH is offline
