2005 6.0 front cover install - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-20-2011, 03:53 AM Thread Starter
Hi, I need to change teh front cover on my 2005 6.0, is there a way to replace it without taking the intake manufold off? I would love to know if there is a way to sneak it in without removing the intake manufold.
SECSPEC1 is offline
post #2 of 12 Old 07-28-2011, 12:43 PM
I think you can do it by loosening the intake manifold and raising the front of it up a little to disengage it from the front cover. Not 100% on this though.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #3 of 12 Old 07-29-2011, 11:46 AM
juzatheman's Avatar
Save time and lose the intake manifold bolts im prety sure that you dont get it between manifold because of dowel pins and crank shaft.
juzatheman is offline
post #4 of 12 Old 07-29-2011, 12:48 PM
What? Don't understand what you're going for there.
post #5 of 12 Old 07-29-2011, 01:37 PM
juzatheman's Avatar
Try to write too fast with iPad ...
I Try to Tell that i Couldnt fitt the front cover back cause of the dowel pins on block,
Had to lift the intake manifold little bit before could get the frontcover back.
post #6 of 12 Old 07-29-2011, 06:16 PM
It can be done without removing the intake, you need to take a pair of punches to stick through the front cover bolts to "force" the cover up onto the dowels. If you have never done a front cover before I suggest you just loosen the intake.
Just another chipped, studded, and deleted 6.0...
Bad6.0 is offline
post #7 of 12 Old 09-19-2012, 01:30 AM
Did it work?
I'd like to hear inputs from people changing the front cover without removing intake. I need a new front cover and I am trying to save a lot of time.
also, does anyone know the ford part number for the crankshaft front seal speedi-sleeve?
thanks,
Derek
fordman62 is offline
post #8 of 12 Old 09-19-2012, 01:49 AM
F350Black's Avatar
Subscribed. I need to do the same thing very soon. If there is no anser soon I'll just end up doing it and taking pictures...
Sent from my SGH-T989
2005 F350 CCLB FX4
Studded, EGR Delete, OEM head gaskets, BPD Oil Cooler, Blue Spring, 35x12.50x18 Mickey Thompson MTZ
Bulletproof
F350Black is offline
post #9 of 12 Old 09-19-2012, 04:25 AM
dnf12908's Avatar
Quoted: 31 Post(s)
thanks,
Derek
I changed my front cover recently to upgrade to the bigger water pump. I did loosen the intake manifold. It makes it a lot easier. Just a note on the speedi-sleeve; one came with my cover kit but I just put the old seal back on. The crankshaft looked good and I didn't want to bother trying to find the sleeve install tool. It's all good.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Insight CS monitor
Harley headlights
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #10 of 12 Old 09-19-2012, 05:19 AM
if you loosen the intake, then crank it back down, how do you ensure the old gaskets seal?
thanks,
Derek
