2006 6.0 High Oil Temp Reading, but Normal oil temp. - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-16-2011, 04:51 PM Thread Starter
I have searched high and low for some info on this issue. I have a 2006 6.0 that the wrench light comes on after about 30 miles. I borrowed a code scanner that reads live data and the oil temp was 255. I used my infrared heat gun to confirm that the oil was actually right with coolant temp. After sitting all night, the temp was still 30-40 degrees higher than the coolant temp. I have read about wire chafing and would like some input. Thanks for some really great reading materials.
Quickvo is offline
post #2 of 14 Old 07-16-2011, 07:45 PM
Send a message via AIM to PowerstrokeTech82787
sounds like a faulty sensor. Could very well be a wire that rubbed through and is either making contact with a voltage + wire or could also be rubbed to a ground.
PowerstrokeTech82787 is offline
post #3 of 14 Old 07-16-2011, 07:59 PM Thread Starter
The sensor was the first thing I tried. I bought a new sensor at the dealer, because I thought 31 bucks was worth the chance. I guess I will have to dig around the harness and see if I can spot anything substantial. Thanks for the reply.
Quickvo is offline
post #4 of 14 Old 07-19-2011, 07:15 PM Thread Starter
No luck on the harness being the cause of my problems. After it sat all night and day, the ECT was 82 and the EOT was 112. I'm still at a loss. Do you think it could be as easy as a complete reset?
Quickvo is offline
post #5 of 14 Old 01-13-2012, 01:34 PM
So is it fixed now? What fixed it?
Dahc28 is offline
post #6 of 14 Old 01-13-2012, 01:40 PM
You may want to check in to whether or not there is a recent flash for your truck.
It may be a programing error. Since the sensor checks good and no wireing problems.
Did you test your heat gun for accuracy?
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #7 of 14 Old 01-13-2012, 08:07 PM
what did u use for a scanner. i have heard with some that if the temps are crazy when the truck is cold, they may need to be adjusted in the gauge device ur using.
joe_r_dog is offline
post #8 of 14 Old 01-15-2012, 10:16 AM Thread Starter
It turned out to be more than one problem. The wrench light was coming on because of a pllugged oil cooler, but the scan tool I was using was known to not be accurate for reading the oil temp. It was a MAC. Now that I have replaced the oil cooler and EGR cooler, all is well.
Quickvo is offline
post #9 of 14 Old 01-15-2012, 09:01 PM
did you go with stock coolers or upgraded?
6lobo9 is offline
post #10 of 14 Old 01-16-2012, 05:36 AM
u shouldve deleted the egr.
Tags
6.0 , chafing , oil temp , pcm
