Losing Power While Driving - Ford Powerstroke Diesel Forum
Old 07-06-2011, 02:59 AM
my 2005 6.0 liter loses boost and power after i let off the fuel and give it fuel again while driving down the highway, could it be my EGR or Injector?
Old 07-06-2011, 03:26 AM
Do you have gauges. Check how much boost rye.making . The turbo vains might be sticking
Old 07-06-2011, 02:24 PM
my turbo is only putting out about 22psi and its a factory turbo not an aftermarket one,
Old 07-28-2011, 08:26 AM
turns out it was my EGR valve, it was sticking open
Old 07-28-2011, 05:30 PM
Did you also get black smoke out of the exhaust when the loss of power occured?
Old 07-28-2011, 05:44 PM
Mine was doing the same thing. Ended up being EGR valve staying open. Got it changed, now the same thing is happening again. I read that shtuff can accumulate in the pipes and clog even a brand new valve. I have to bring mine in again.
Old 08-04-2011, 07:31 AM
My all stock 05 doe sthe same thing, If you let off the gas and get back in it, it will not spool back up. I cant get it to run over 5lbs anymore. Does anyone have any suggestions?
Old 09-30-2012, 04:11 PM
Get a new egr valve and take it in for a egr delete kit
