what oil to use? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-05-2011, 06:20 PM Thread Starter
06kngrnch84's Avatar
what oil to use?
I have been hearing different stories about what oil to use. I hear use 15w 40, somebody else says 5w 40. I live in Mississippi, summers r hot and humid, 115 degree heat index and 100% humidity. Winters are usually mild down in the teens about a total of a week spread throughout the winter, the rest of the time mid 20's to mid 30's. I have been using rotella t6 15w 40. Should I change or stay the same?
Jackson, MS. 2006 Ford F-350 SRW King Ranch FX4 Crew Cab, All Stock, 160,000 miles
EGR Delete
Updated HPOP Fitting
Updated Standpipes and Dummy Plugs
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
'04 Metal Cold Side CAC Tube
06kngrnch84 is offline
post #2 of 2 Old 07-05-2011, 07:15 PM
Acidsniper's Avatar
T6 5-40 is about the best bang for your buck. The lower number (5 in this instance) is the cold viscosity index, which in hot weather doesn't really matter. The second number (40 in this instance) is the Hot viscosity index, or how well it flows when hot.
A 5-40, 10-40 and 15-40 will ALL have the same viscosity index when hot. I use 5-40 because it's the best all around year round oil weight to use. You don't want to be running a 15 weight in any type of cold weather.
~JW aka "Acidsniper"
2006 King Ranch CCSB FX4
MBRP 5" Turbo Back
DC Power 270 Amp Alternator
Airaid CAI
Edge CTS
Bushwackers
Recon mirror lenses
Dieselsite Coolant Filter
T6 & Rev-X
Proud Navy Vet
Acidsniper is offline
